Cleaning an o2 sensor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2007, 11:56 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Has anyone ever had any luck cleaning an o2 sensor. If so how? I have two pretty new sensors that I think are bad. So I have nothing to lose by trying to clean them.
Last edited by weirdbeard; 11-11-2007 at 12:48 PM. Reason: I spelled think like thing. I am only one year old!
Old 11-10-2007, 01:52 PM
Pull them out, if they're covered in black soot wipe them off then put them back in, run the engine at 2000 rpm or so in neutral until they start switching between rich and lean. If they don't they're no good. From reading your other posts they're probably fine and you have a fuel or ignition problem. There are some liquid gasket compounds that will kill an O2 sensor also. They'll usually say right on the tube if they're ok to use on O2 sensor equipped vehicles.
Old 11-10-2007, 05:23 PM
Wiki Edits: 31
some RTV's are non o2 sensor safe, most are but some
Old 11-11-2007, 11:53 AM
weirdbeard's Avatar
1976 Ranchero GT
Yeah thats what got me thinking I killed my o2 sensors by cleaning the MAF with deoxit contact cleaner. I never stopped to think that it might hurt the o2s. I don't think my scanner will show the sensors switching. I just get freeze frame data. I got what I paid for.
Old 11-11-2007, 08:13 PM
Wiki Edits: 31
probe the sensor w/ a dvom. it's a voltage generator
Old 11-11-2007, 09:37 PM
Would Eyther hurt an O2 sensor?Only thing I have ever used it for besides putting tires back on their beads(I know bad Idea) is for cleaning sparkplugs,But if an engine was soaked with eyther couldd it hurt the O2 sensor,Probabally what poped the head gasket.
Shane
Old 11-18-2007, 11:09 AM
weirdbeard's Avatar
1976 Ranchero GT
I don't see a good way to probe it. I am afraid that I will just make another problem for myself.
Old 11-18-2007, 01:36 PM
You can back probe the O2 sensor signal wire at the ECM or at the first connector safely. I use a safety pin and connect my DVOM to the safety pin. Just be sure the safety pin doesn't ground to something. You're right in not wanting to puncture the O2 signal wire at the O2 sensor. Most of the newer O2 sensors use a shielded wire casing that shouldn't be punctured. At 2000 RPM the voltage reading should fluctuate between roughly .2 and .8 volts. I think I mentioned this before, but have you done a voltage drop test on all of the power and ground circuits for the ECM?
Old 11-18-2007, 02:15 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I think it was you who I described the Actron Sensor scan tool to, and it worked for me with no problems. I just had to heat it hot enough to get it to switch.
In a while, Chet
Old 11-18-2007, 03:33 PM
weirdbeard's Avatar
1976 Ranchero GT
Thats a good idea about using a safety pin to back probe the harness connector. The probes on my multi meter are way to big.
My Actron scanner does not show live data. It is still a helpful tool.
I don't know what a voltage drop test is. Is that where you read voltage at one place and then farther down the line and compare?
Old 11-18-2007, 04:09 PM
Anyone tried the propane torch trick to test a sensor? I had heard of it but was afraid to try it until I read about it in the Auto Zone repair guide. I never could get a reading but I am not sure if the sensor was bad, maybe I did something wrong or was just afraid to heat it hot enough? Whatever, I never could tell if it worked or not and was just curious if anyone else has tried this?
Old 11-18-2007, 05:20 PM
weirdbeard's Avatar
1976 Ranchero GT
Seems like there would be to much oxygen for the sensor to produce voltage.
Cavalier O2 sensor ? Eric64 Engine 8 04-11-2006 07:07 PM
O2 sensor problem william27103 Engine 2 01-06-2006 05:55 PM
'94 LT1: rough idle plus O2 sensor question hduff Engine 2 12-10-2005 03:04 PM
O2 Sensor? 97Z28 Engine 2 11-17-2005 10:39 PM
O2 sensor crshrmn3 Engine 2 09-01-2003 02:12 AM
