-   -   cleaning pistons! (http://www.hotrodders.com/forum/cleaning-pistons-111120.html)
beach_boy327 03-11-2007 03:25 PM
cleaning pistons!
what is the best thing to use for cleaning the carbon of of pistion befor i reinstall them?
thanks
Guy Hiltz 03-11-2007 04:11 PM
cleaning pistons!
A brass wire wheel on a drill is what I have used before,seemed to work OK.
beach_boy327 03-11-2007 04:16 PM
pistons
thats what i was thinking to, but i wasnt sure if that would scratch them!
xntrik 03-11-2007 04:21 PM
piston tops only.
redlightning 03-11-2007 05:00 PM
I just put some rings in my 91 prelude.It was an oil burner so the tops of the pistons had a lot of carbon on them(in the center of the piston).I soaked them in my parts washer and it didn,t seem to help much.
I had some BG intake cleaner that I had not used.I soaked them in it and the carbon came right off. :D
I don,t build engines that often.I would kinda of like to see what others use also.
GearJamminHero 03-11-2007 05:16 PM
Originally Posted by xntrik
piston tops only.
x2.
You dont want to let that wheel touch the ringlands or skirts, especially if they are anodized or have some coating. Chrysler sells combustion chamber cleaner, I hear it works pretty well.
strikingthematch 03-11-2007 06:42 PM
When I cleaned my off I had my engine on a stand so this was a little easier to do. Rotated it so that the side I was cleaning faced down and slightly to the side. The bores on either side of the piston I was cleaning where tapped over so that no dirt got in them, also keeping the holes for the head bolts covered. Rotate the positions till the one you want to clean is at TDC and used a wire wheel to clean it.
The bore was lubricated with a thin coating of oil since the engine had been out for an extended period of time.
I took a wire wheel and went over the large portions of the piston till it was clean
The small dishes in the piston easily cleaned with a brush. Getting all the little bit out if there can be a pain but it completes the job.
When all the work was done the finished piston was rotated back down the bore the oil caught most of the dust.
I cleaned the oil away from there and the job was done. Also make sure to wipe down the piston top for left over dust.
A nice repeat process to go on from here and of course a double triple check at the end just remember how little it takes to kill a bearing.
... for an engine in a car i would use the same process but be even more careful about dust falling down into the ring land while cleaning. best of luck.
Chris
GMCTRUCKS 03-11-2007 07:17 PM
Cleaning
What truth does soaking piston in Coca-Cola do for removing carbon off them I heard that once but never tried it.
Lil Big Mec 03-11-2007 08:23 PM
Would probably work pretty good. Ever dropped a nail in a can of coke? Gone in less than a week! :eek: Personally, I've had good (great actually!) success soaking them in carb cleaner.
cabowabo 03-11-2007 09:01 PM
man dude
its hard to snort coke pistons up the nose
joe_padavano 03-11-2007 09:15 PM
Oven cleaner is the best, least expensive way to remove carbon deposits.
junior stocker 03-11-2007 09:22 PM
Used to use Hydroseal, a decarbonizer. Gunk makes a similar product. Kerosene soak overnight. I stay away from any kind of wire wheel or brush. Just soak overnight in the right stuff, use a parts brush, and bright shiny aluminum. BUTCH.
ChevelleSS_LS6 03-12-2007 12:09 AM
http://www.sohc4.us/forums/index.php?topic=18647.0
mike 96 ws6 03-12-2007 12:18 AM
I would not suggest applying oven cleaner {acid} to a set of pistons.
A quality ring grove cleaner can take care of the carbon deposits there. A dishwashing pad made of brass guaze {Chore-Boy ect.} can clean most of the surface stuff on the skirts whithout gouging, and the carbon on top can be scraped with a dull pocket knife. The trick on the top of the piston is to keep a smooth surface, even if it means leaving a thin layer of carbon in some spots.
True: Excessive carbon film on the top of the piston can lead to preignition issues.
And, 'No carbon' is excellent.
But: Scatched surface imperfections on top of the piston will created an area for carbon to collect in that space and will enhance combustion chamber ignition local to that specific area of the piston, rather than allowing a uniform charge ignition across the piston top in that chamber.
JMO :)
Have Fun !!!
techinspector1 03-12-2007 01:11 AM
If you are going to scrape or wire brush the pistons, run each one up to top dead center to do it, then use a shop vac with a snorkel attachment to vacuum the crud from around the ring lands. I've done it many times. No shop vac? Use mom's or girlfriend's or wife's vacuum cleaner.
