cleaning pistons!
what is the best thing to use for cleaning the carbon of of pistion befor i reinstall them?
thanks |
pistons
thats what i was thinking to, but i wasnt sure if that would scratch them!
You dont want to let that wheel touch the ringlands or skirts, especially if they are anodized or have some coating. Chrysler sells combustion chamber cleaner, I hear it works pretty well. |
When I cleaned my off I had my engine on a stand so this was a little easier to do. Rotated it so that the side I was cleaning faced down and slightly to the side. The bores on either side of the piston I was cleaning where tapped over so that no dirt got in them, also keeping the holes for the head bolts covered. Rotate the positions till the one you want to clean is at TDC and used a wire wheel to clean it.
The bore was lubricated with a thin coating of oil since the engine had been out for an extended period of time. I took a wire wheel and went over the large portions of the piston till it was clean The small dishes in the piston easily cleaned with a brush. Getting all the little bit out if there can be a pain but it completes the job. When all the work was done the finished piston was rotated back down the bore the oil caught most of the dust. I cleaned the oil away from there and the job was done. Also make sure to wipe down the piston top for left over dust. A nice repeat process to go on from here and of course a double triple check at the end just remember how little it takes to kill a bearing. ... for an engine in a car i would use the same process but be even more careful about dust falling down into the ring land while cleaning. best of luck. Chris |
Personally, I've had good (great actually!) success soaking them in carb cleaner.
man dude
Oven cleaner is the best, least expensive way to remove carbon deposits.
Used to use Hydroseal, a decarbonizer. Gunk makes a similar product. Kerosene soak overnight. I stay away from any kind of wire wheel or brush. Just soak overnight in the right stuff, use a parts brush, and bright shiny aluminum. BUTCH.
A quality ring grove cleaner can take care of the carbon deposits there. A dishwashing pad made of brass guaze {Chore-Boy ect.} can clean most of the surface stuff on the skirts whithout gouging, and the carbon on top can be scraped with a dull pocket knife. The trick on the top of the piston is to keep a smooth surface, even if it means leaving a thin layer of carbon in some spots. True: Excessive carbon film on the top of the piston can lead to preignition issues. And, 'No carbon' is excellent. But: Scatched surface imperfections on top of the piston will created an area for carbon to collect in that space and will enhance combustion chamber ignition local to that specific area of the piston, rather than allowing a uniform charge ignition across the piston top in that chamber. JMO Have Fun !!! |
If you are going to scrape or wire brush the pistons, run each one up to top dead center to do it, then use a shop vac with a snorkel attachment to vacuum the crud from around the ring lands. I've done it many times. No shop vac? Use mom's or girlfriend's or wife's vacuum cleaner.
| Blower pistons | malibu68 | Engine | 15 | 12-14-2006 08:49 PM |
| ? about dome piston's | bowtieorbust | Engine | 5 | 09-19-2004 07:34 AM |
| Long skirt SBC pistons | fierosum | Engine | 9 | 01-16-2004 07:02 AM |
| Cleaning Heads & Pistons | DTL504 | Engine | 2 | 11-09-2003 06:13 PM |
| cleaning around pistons? | dans57chevy | Engine | 7 | 03-13-2003 04:10 PM |
