Cleaning Solution - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2003, 12:42 PM
84 Z28 Convertible
Cleaning Solution
What is the best solution to clean the carbon buildup off my heads & pistons. I took the heads off to change the gasket and would like to clean them up before I put it back together. Will a wire brush be sufficient or gunk.
Old 11-09-2003, 12:49 PM
Jmark's Avatar
Good'ol Easy off oven cleaner will disolve most of the goo on the heads. Spray em good and bag them in plastic trash bags and let them sit for an hour or so. If left unwrapped, it will dry out fast and not do much.
Old 11-09-2003, 06:09 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
DO NOT USE A WIRE BRUSH as it will scratch and collect more than before, plus it make's weak spot's in certain metals.
Do like Jmark recommends or put on some Marvel Mystery Oil, let it soak in and cut down a paint brush to about 1" and use it to scrub off the carbon deposits.
BTW this is your second posting asking the same question.
Luv the smell of NITRO in the morning.
