Cleaning up Guns... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2010, 08:47 AM
Cleaning up Guns...
ok guys, I want to paint water based paints, and I just bought one of those inexpensive chinesse guns but I wonder how do you take the grease that comes from the factory.. with lacquer thiner, acetone, alcohol.. windex..
Old 02-21-2010, 10:03 AM
Vegaguy's Avatar
I used laquer thiner on mine to clean mine. They go a little overboard on the oil on those guns.
Old 02-21-2010, 01:39 PM
thanks...but how do I clean the guns after I use the lacquer thiner?..or will the lacuqer thiner just evaporate without any problems happening in the future... I dont' want any of the lacquer thiner mix with the paint...
Old 02-22-2010, 09:13 AM
cyclopsblown34's Avatar
Colorsanding painter
The lacquer thinner will evaporate in minutes if you hold the trigger until the thinner stops dripping out. If it is a siphon feed, once you dump the cup out, leave it apart a few minutes and the thinner will evaporate.
Old 02-22-2010, 11:16 AM
Irelands child's Avatar
Just a note - use automotive lacquer thinner as the Home Depot stuff has trace oils and water that will leave a residue. Most auto paint supply shops have a cheap ($8-10/gallon) version that is good enough.
Dave W
Irelands child
Old 02-22-2010, 02:16 PM
Dave W
Can I use rubbing alcohol after the thinner to be shure there is not redue?..
Old 02-22-2010, 02:34 PM
You might have even worse residue problems - most rubbing alcohol again has oils.
I see you are in Africa - which is a kinda large continent but without knowing where - not a clue as to hard it is to get an automotive paint thinner, but that's the best, has less crap in the mix and is the way to go - but if local thinner and denatured/rubbing alcohol all you have - go for it with a good gun parts wipe down before spraying.
Just a question - most African countries I've been in couldn't care if you use a solvent based paint - why the water based?
Dave W
Irelands child
Old 02-22-2010, 03:07 PM
Dave W
actually I am living in the u.s.a now...
Spring Cleaning For The Members: Tips Only Racing Hotrodders' Lounge 15 03-13-2008 07:02 PM
TEKZ HLVP guns ?? jimmy1 Body - Exterior 10 10-22-2007 06:29 AM
How Many Guns do I Need? cab Body - Exterior 9 06-17-2006 04:37 PM
Will my compressor keep up with these guns? gator412 Body - Exterior 12 04-18-2006 10:15 AM
Astro Guns? Opinions please novafreek6872 Body - Exterior 11 01-11-2006 07:58 PM
