Charcoal lighter, test it first, it works on most paints.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
I have heard all these solutions before. But.. do I not have to worry about strong solvents dissolving the clear coat? I have a bottle of the purple solvent that many use, and it cleans grease very well. But I am hesitant to try it on a painted surface.
Thanks for the input! |
During winter when my car sits more, I jack it up in the driveway and remove the tires and wheels. I get the cheap liquid laundry detergent and mix up a bucket with hot water. Then I use a brush I have with a long handle and scrub everything I can reach with it. Use a mitt after that to get whatever I missed. Rinse it and then use the same spray detailer I use on the body to wipe it down.
They never look as good as the body, but if you wanted to polish or wax them, they might get closer. |
Cole
what if you high pressure power washed it? Usually, that works pretty well but unscrew any extraneous parts before hand or they may end up in your backyard, or even someone else's!
http://www.governmentauctions.org/aNoFeeCarsByState.asp |
| removing wheel wells! | cudablack2004 | General Rodding Tech | 4 | 06-23-2011 09:40 AM |
| Coating for fiberglass wheel wells. | americanLT1 | Body - Exterior | 2 | 04-08-2009 10:12 AM |
| Fiberglass wheel wells amost done. | americanLT1 | Body - Exterior | 7 | 04-14-2008 07:56 AM |
| Help with wheel wells? | workingclass | Body - Exterior | 29 | 02-14-2006 10:20 AM |
| Cuting wheel wells | Chucks,57 | Body - Exterior | 2 | 05-08-2003 02:36 PM |
