Cleaning valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2003, 07:06 AM
Cleaning valves
Have my heads apart on a '89 Cadillac. Valves are coated with a hard crud. Have some really strong solvent (Gunk carb & parts cleaner in a gallon can) but it doesn't do anything for the crud. Managed to scrape it off with a small knife, but I got maybe four valves done in 2 hours (only 12 more to go...!)
Anything that will take this stuff off besides a hot tank? On the exhaust valves, its mostly carbon, and it'll soften a bit in the solvent. The intake valves have a beige coating that's almost like a ceramic.
Old 06-26-2003, 08:34 AM
4 Jaw Chuck's Avatar
Wire brush mounted on your bench grinder works wonders.
Outlawed tunes from outlawed pipes
Old 06-26-2003, 08:36 AM
I thought of that, but was worried it would be too easy to hit the lip by mistake. I don't need to get them reground, just lightly lapped. Maybe I can at least use it to get most of the gunk off, then manually hit the edge close to the lip.
Old 06-26-2003, 08:37 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Even a wire brush on an eleectric drill will work. Mount the valve in a bench vise using wood to protcect the valve from the jaws of the vise and you should be done in a few min.
Old 06-26-2003, 08:38 AM
Hellzapoppin's Avatar
Try putting each valve in your electric drill, switch on and use fine emery paper. Its easier if you have a pillar drill but if not get the wife to hold the drill and you use the paper.
Old 06-26-2003, 08:40 AM
don't worry about he lip. The valve is much stronger than the wire wheel. When you re-lap the marks will be gone from the margin and head.
Old 06-26-2003, 08:44 AM
Wow. Thanks guys for all the info.
I guess I was being overly cautious. Your tips will make it go a lot faster.
Old 06-26-2003, 09:52 AM
Wear a mask when your doing it, there are some nasty deposits on there.
Old 06-26-2003, 09:53 AM
Good point. Nothing that could be deposited on a valve could be described as "healthy".
Old 06-26-2003, 03:49 PM
MI2600's Avatar
Member# 3287
I've seen wheels made out of something like scotchbrite advertised...maybe in Eastwood...that you can mount on your bench grinder for that purpose. You might find something similar in the local hardware.
