clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2004, 01:20 AM
camnova's Avatar
New Member
clear
just woundering if you can clear coat bare metal for the metal look without it rusting. or would you have to get it painted crome.
i think this would look awsome since u dont see it ever.
Old 08-04-2004, 07:13 AM
suck, squeeze, bang, blow
Last journal entry: finally reeled it in
I clear coated a bare metal Air Cleaner on a Goldwing once. It lasted for about a month, then it started to peel. A buddy of mine clear coated a stainless motor cycle tank, but he used a clear epoxy flooring chemical, airbrushed a graphic then cleared coated the whole thing with Deltron. It's still running around as far as I know.
Old 08-04-2004, 11:49 AM
BarryK's Avatar
Clears actually stick pretty good to bare steal and aluminum but the problem is they have no tolerance for oxides or corrosion.
So if cleaned perfect clear might stick for 1 week to a year at best.
I have an aluminum rack I made for rover and over the last 4 years
I have gotten the clear to last 6-9 months, nice part is when it peels all you need is an air gun to strip the rest off. and reclear again.
