Clear Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2008, 06:04 PM
Clear Coat
This is my first post and my first renovation project. I have purchased a Silver 1985 Toyota MR2. It has the original paint and clear coat. The front hood's clear coat is peeling off. I will eventually be painting the car (the same color as it's orignial), but want to protect what paint is there (which BTW is in pretty good condition) until I can get it painted. So my question is: 1) can I get the clear coat off? 2) can I protect the paint underneath it? and 3) HOW?
Thanks in advance for your help.
RaeMR2
Old 01-22-2008, 05:00 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
That would be pretty difficult.
Even if you could remove only the clear coat, the base would
be scratched and marred at the very least, so it wouldn't look
right once cleared.
Base is very easy to marr and damage without clear on it.
Besides, if the clear isn't sticking now, the new clear may not either.
You need to at least sand through all the clear and scuff up the base
real good, I'd recommend sanding most of the base off to be safe.
And if you want a real "durable" job, like a hood where you want to
minimize rock chips, then a primer coat of epoxy before painting is
the best insurance. It'll make stronger adhesion.
You just can't trust whats there, the more you remove, the better
in the long run.
Clear coat sandthrough oldred Body - Exterior 7 10-19-2006 07:07 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Clear coat repair don't match Ratchet Body - Exterior 31 12-13-2005 10:11 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
Can I Spray Clear Coat Over Clear Coat ??? STATUTORY GRAPE Body - Exterior 2 10-07-2003 09:09 AM
