"Clear Coat" for Engine ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2002, 09:46 AM
white66coupe's Avatar
Post "Clear Coat" for Engine ?
Hello,
I'm painting my engine bay a nice black and I am repainiting my valve covers and part of the engine block.
Anyways, instead of leaving the paint exposed it would be nice to put a clear coat on the Valve covers and even abit on the engine where colant seems to always drip.
Question: Is there such thing as High-Heat Clear Coat? Has anyone used regular clear coat in the engine bay area with any success? Will clear coat turn yellow?
Just looking for thoughts or feedback.
Thanks, Greg.
Old 12-06-2002, 09:52 AM
Maverick's Avatar
Post
Yep Plasti-coat makes a high temp clear. Get it at Auto Zone. I have a can of it but havent used it yet.
Old 12-06-2002, 11:00 AM
MI2600's Avatar
Member# 3287
Post
I use Plasti-Kote paint. With the other paints you have to wait a week before you can recoat. I've tried their clear-coat on an aluminum intake and it turned yellow. Personally, I think their regular paint gives you enough gloss.
Old 12-06-2002, 11:26 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
The last item I tried was PPG Concept 2000 catalyzed urethane normally used for painting bodies. I sprayed my heads and they are doing great, even around the exhaust ports.
Old 12-06-2002, 01:27 PM
Post
I used plasti kote on my new intake and it stains bad with gasoline. Made the intake look a little yellow right after it was dry to the touch.
