Clear coat the engine after painting it.??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 09:58 PM
So I am going to paint the engine the same body color as my car is. Now I am concerned that the paint will not hold up to the heat of the engine and will peel off. Now I found a clear coat that is good up to 1200 deg. F..
So if I paint the engine and the apply the clear coat do you think this will "seal" the paint on the engine and prevent it from peeling?..
Shoot me your opinions.. Thx. Mark
Old 07-13-2005, 10:08 PM
TWOPLYM's Avatar
New Member
paint
well i now for a fact that u can buy the paint alone that will withstand the heat. dont know if u really need the clearcoat,maybe just for car shows and trailer queens
Old 07-13-2005, 10:12 PM
willys36@aol.com's Avatar
Wiki Edits: 21
As discussed many, many times on this forum, quality automotive catalyzed urethane base coat/clear coat will stand up on an engine very very well. Will take all the heat (short of direct exhaust heat) and chemicals you can throw at it and keep going. Superior finish to any rattle can paint on the market.
Old 07-14-2005, 05:35 AM
I Painted A 350 One Time All With Hok Products, Cleaned It Sanded It Epoxyed And Spray Hok Shrimrin Bases,and Cleared, Still Holding Up Very Well. Mike.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
pinstriping base coat / clear coat apehanger mike Body - Exterior 1 01-30-2005 12:28 PM
Clear coat problems jmi Body - Exterior 3 10-15-2004 07:41 AM
Problems with Clear coat xerox Body - Exterior 1 09-06-2004 05:29 PM
Clear Coat Question EazyDuzIt102 Body - Exterior 3 03-29-2004 05:08 AM
