Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clear coat help
Thread: clear coat help
Old 09-28-2012, 03:03 PM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
if you're using a fast activator and the temp is already close to or above the range it is suited for, it'll dry very quickly and give you peel and/or dry spray. Make certain the activator you're using matches the temperature of the spraying time. Did that make any sense?
