Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clear coat help
Thread: clear coat help
Old 10-01-2012, 12:32 AM
inkfreak1976 inkfreak1976 is offline
Originally Posted by cyclopsblown34 View Post
if you're using a fast activator and the temp is already close to or above the range it is suited for, it'll dry very quickly and give you peel and/or dry spray. Make certain the activator you're using matches the temperature of the spraying time. Did that make any sense?
yes it makes sense, and i do do that i always use the slowest activator i can so the top coat has time to flow as much as possible.
