To clear coat or not to clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 09:14 PM
Jeepster's Avatar
No such thing as "Too much"
I'm in a bit of a jam, and I need some advise. My paint booth is very large, it includes all of outdoors if you know what I mean. I was painting a bc/cc system when I had a boo boo. I had to stop and allow the base to dry hard and then sand a portion of it back down to primer to clean up the problem.
The issue is the weather turned on me, and dropped into the 40's with rain every day for a week after. Now the rain is stopped, but they are not predicting any temps above the 50's for a week, and it cold be for months now.
My question(s) are:
1. What will happen if I apply another coat of base and then clear coat at a temperature below 60 degress?
2. Since this is my parts running truck I'm not worried about a show quality paint job, what will happen if I just stop here and don't apply the clear coat?
Thanks, Jeepster
Old 10-23-2005, 10:10 PM
There was a recent discussion related to this. Here is the link. Crosslinking and Temperature The base really has no protection without a clearcoat, so that is not good either. The best thing I can think of is to sand the base and wait till the temp gets above 55 to apply more base and clear. But I would keep it inside and out of the elements if only in base. Either that or start looking for a heated place to paint, even if you had to rig up a temporary booth and find something to heat with. My garage isn't insulated but try to warm it up well before spraying and once its clear of overspray and clear has set a little heat again for another round.
Old 10-24-2005, 07:27 AM
Jeepster's Avatar
WOW, Thanks a bunch Kenseth17! There were a lot more reasons to avoid painting in the cold then I thought!
My Willys project has the garage tied up for at least two more years, so I guess that I just need to bite the bullet and wait, even if it means sanding it down and repainting. I'd rather do that then have it all back together and have to start from scratch.
Arrrgg! Clear coat flaking off!! dpowers Body - Exterior 16 04-01-2008 12:10 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 01:22 AM
base coat clear coat wally Body - Exterior 8 12-12-2005 07:44 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
Can I Spray Clear Coat Over Clear Coat ??? STATUTORY GRAPE Body - Exterior 2 10-07-2003 10:09 AM
