Clear Coat over Aluminum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2009, 11:37 AM
Last journal entry: Front Fender
I just finished my center console. I brushed the aluminum and glued it to
the console. The sides need to be clear coated and I would like to do the
aluminum also. Anyone have experience clear coating aluminum?
Thanks
Old 04-24-2009, 05:40 AM
Here's two things you can try , you could see about getting the parts powder coated but that may be a little pricey . Or you could check into this ,
it's called X-I-M 900 clear coat you can pick this up a your local Sherwin Williams . It's made for clearing chrome , aluminum or just about anything and requires no thinning . Hope this helps.
Rocky
Old 04-24-2009, 06:49 AM
cboy's Avatar
Last journal entry: Finished
Looks good from the picture. What method did you use to do the brushing?
I've powder coated clear on aluminum (using my Eastwood coating gun) and it turned out OK. But if you don't want to go to that expense you could also use any of the good spray on's for aluminum rims. Also ZoupsSeal is supposed to be good and I've even read of people using beeswax. Keep in mind most of these spray on products will probably need to be redone every couple of years to keep them looking really sharp.
Always learning...and sharing what I've learned.
Old 04-24-2009, 07:34 AM
speede5's Avatar
go fast, turn left!
I like the aircraft gauges, I see a compass, and not sure what else. What are the others and what are they from? Do you have a closer pic?
Old 04-24-2009, 07:35 AM
willys36@aol.com's Avatar
Wiki Edits: 21
I have clear powder coated transmissions, valve covers, and other engine parts with great results. Your console would be a piece of cake. IF powder coating is the Rolls Royce, then catalyzed clear coat would be a Cadillac. Either should look great and last forever. Both come off easily w/ quality paint stripper so danger is minimal.
Flames without the clear coat?? Yes or No Jim Weeks Body - Exterior 4 04-13-2009 05:21 PM
Base coat clear coat repair problem TimeBandit Body - Exterior 2 09-03-2008 06:22 PM
Clear Coat RaeMR2 Body - Exterior 1 01-22-2008 05:00 AM
Clear Coat Problems Help!!! coupe33 Body - Exterior 4 01-01-2008 07:55 AM
Clear coat delaminating, can I stop it? Jeepster Body - Exterior 4 07-07-2006 05:50 AM
