I third the motion..however...WATCH OUT! Some stripe kits are made from vinyl that release vapors when heated (like in the sun). If you put clear over this type of vinyl, it will push your clear up and either make air pockets, or push it completely off. Your paint job will look 1000% better if you take HK's advice and use the stencil kit to tape off the area you want to paint with 3M blue 1/8" fineline tape and spray the color with basecoat paint, then clear the entire car. The edge will be 'flatten-able', and the car will look right. Anytime you put vinyl on a car, when you wax it, you will get that wax white line at the edge of the vinyl where you have a hard time rubbing it back out. If your determined to use the vinyl, call the manufacturer to make sure that it's coverable with urethane clearcoat.
The 'hopper
