Clear coat question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2006, 04:54 PM
GMW GMW is offline
When clearing something with lots of nooks and crannies, like a wheel, that most likely won't be buffed out. Should I do anything different?
It just seems to me that clear coat is more vunerable to scrathing, etc. if it hasn't been color sanded and buffed.
Thanks
Old 10-12-2006, 05:22 PM
colormecrazy's Avatar
Paintshop Dog
Most urethane clears should not be any more vulnerable sanded and buffed or not. As for the tips on wheels, If there are many nooks and cranny's, I would use a smaller gun (miniJet). This just gives you more control in smaller areas.
Good Luck!
Old 10-12-2006, 07:36 PM
302 Z28's Avatar
You need to get the clear to atomize really good to get into all those nooks and crannies. Whatever gun you use crank up the air pressure to around 40-45psi.
Vince
Old 10-12-2006, 07:39 PM
Paintshop Dog
Careful not to run it at high pressure.
Old 10-12-2006, 07:49 PM
adtkart@aol.com
Man.... It's a pain to get those runs out of those nooks. LOL
Aaron
Old 10-12-2006, 08:40 PM
Paintshop Dog
It's even worse to have the runs in your cranny's!
Arrrgg! Clear coat flaking off!! dpowers Body - Exterior 16 04-01-2008 11:10 AM
Question for Barryk.. turbo clear related. beemdubya Body - Exterior 5 05-09-2005 04:28 AM
Paint not adhering to original clear coat on side moldings. myfamiliacc Body - Exterior 7 04-25-2005 05:24 AM
pinstriping base coat / clear coat apehanger mike Body - Exterior 1 01-30-2005 12:28 PM
clear coat compatability 2cati Body - Exterior 2 09-17-2002 06:25 PM
