clear coat sags??
This week my 15 year old painted the hood on my 41 Pontiac. [Its a driver not a show car. The original paint is poor but the hood was a mess, so we decided to redo it for now and put off a full blown resoration till later. It also seemed like a good practice run for painting his car in a few months]
The body work, primer went well and the base coat looked great. [Dupont BC/CC ] It was 101 degrees outside and nearly that in the shop. When he sprayed the clear coat he had a bit of trouble. Seemed to be drying in the air and looked a little like it would orange peel, so he adjusted some and started laying down a nice smooth wet coat. Then it started sagging. 1. should we have tried to do something when the paint was wet? [we didn't] 2. Some of the sags sanded out this morning and I could probably polish it out, but we broke through to the BC in a couple of small areas, so I think we will reshoot the entire hood. Should I just wetsand the entire hood with 500 grit and shoot it? 3. Any tips to avoid a repeat? If he had continued as he started (a little dry, a little orange peel) would that have been better and just sand/polish it out? 4. This morning there appears to be splotching in the BC. It has some metallic in it and kind of looks like the metallic "bunched up" in places. Did not look like that before the CC. Can the CC cause the mettalic to move, or was this an error in application. Again, how do you prevent it. I don't expect this to come out perfect (wouldn't go with the rest of the paint job if it did) but we would like to learn from this. Any help is appreciated. |
When the clear is going on smooth it is very easy to apply too much, especially for a novice....ask me how I know this
. You make a pass and then see what looks like a dry spot and you hit it again....run. Leave that dry spot and cover it on the next coat. It is far better to build up multiple coats, upwards of four to achieve sufficient thickness rather than hog it on in one or two coats.Vince |
Clear coat sags
Thin down the clear. Here in Oklahoma, we commonly paint in 105+ temperatures, and the best way I've found to counter the heat is reduction. Prior to clear, make sure you guys are letting the basecoat flash, and widen the pattern with about 20% more reducer, also. Too little reducer will skin over the base, trapping in the solvent that causes mottling later. The slow reducers used in high temps need a little more time to evaporate the tail solvents. When you clear, use a reducer in the clear to thin it down enough so that you aren't having to pour on the clear to produce smoothness of finish, since thicker globs of clear will require a heavier application to get rid of the peel. Also, less pressure is required to spray. You may need an extra coat to get a good build, but it's better than a re-doo. Also, if you get a run, don't be scared to break out the rough paper. When I get a run, I'll take a sharpie and scribble over the run. Then take a 6" foam waffle block (stick-it) with some 400 grit to knock off the high spots. Take it slow, and don't sand like it's primer or something. Use your fingers to hold the block slightly off the surface, letting the waffled surface of the pad cut off the peaks of the run. Work with progressively finer paper until the sharpie marks are removed. It takes some practice, but if you ain't gettin' runs, you ain't tryin hard enough!
My $.02
Sounds like a few things to me. The heat probably had some to do with it. But most of it sounds like we need a little practice. As for the sags, that's Ok don't worry. Pay close attention to the distance away from the panel. Remember, distance, pressure, overlap, and speed. Stay consistent. As for the modeling (bunching metallics), try what's called an orientation coat. On the last coat of base (after you've got full coverage), try turning the pressure down about 10 lbs. holding the gun at about a 45 degree angle, back off the panel a few more inches, start at the middle from either side and lay an almost wet coat. Go for a kind of even satin look. I know this sounds crazy but I do it almost every day. Once you get the hang of it and dial in it's a sure fire way to lay even metallics. Granted maybe not the first time. But modeling rarely shows before you clear, so it's tuff sometimes to get it just right. Good Luck!!
Warning!! more reducer may not be advisable! It's hot in Texas too, and I don't over reduce. ps Please encourage your 15 year old to use his head and stay in school! The glamorous life of a painter ain't what it's cracked up to be!
clear coat sags
Colormecrazy, I'd like to know what paint you are using, since we have changed to DuPont after trouble-free years of PPG. It's been quite an adjutment, to say the least! This is simply how Iv'e adjusted.
A few weeks ago I toured the Corvette factory in Bowling Green. The tour guide made a point of telling us they use DuPont paint. You should have seen the orange peal on those brand new Vette panels and bodies, it was atrocious. At the end of our tour we were asked to evaluate the tour. I thought it was outstanding and I let them know, but I also let them know about the orange peal. The tour guide acted like it wasn't the first time she had heard it. She did say that the Vette factory has a new paint manager, so maybe improvements are forthcoming.
Vince |
what paint?
ps Didn't mean to be rood about the over reduction. I just like to stick to the books on mixing. I'm a great painter but, not a chemist. |
| "Basic of Basics" How do you properly apply filler? | Centerline | Body - Exterior | 2 | 02-10-2006 12:22 AM |
| Clear coat repair don't match | Ratchet | Body - Exterior | 31 | 12-13-2005 10:11 PM |
| base coat clear coat | wally | Body - Exterior | 8 | 12-12-2005 06:44 PM |
| To clear coat or not to clear coat | Jeepster | Body - Exterior | 2 | 10-24-2005 06:27 AM |
| Can I Spray Clear Coat Over Clear Coat ??? | STATUTORY GRAPE | Body - Exterior | 2 | 10-07-2003 09:09 AM |
