Clear Coat that sticks to Gelcoat? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 08:34 AM
Hey guys,
I recently discovered the HOK Kosmic Glo that makes your car glow in the dark. Now I think putting it on a car would be pretty ghetto, and look retarded because I would get sick of looking at it EVERY DAY. BUT putting it on my boat would be pretty darn cool. I have a 20' Wakeboard boat and we do a lot of night riding.
The issue is, you have to put the Kosmic Glo powder into the clear coat, and I dont know of any Clear Coat that would stick to Gelcoat.
Anybody know of one? Here is a pic of the boat. I think it would be sweet to ake the yellow glow so you would see the outline of the decals
[IMG][/IMG]
Old 02-08-2012, 10:13 AM
I am pretty sure it you sand the gelcoat with 320 to 400 grit sandpaper, you will get good adhesion.
Many boat repairs are done by using paint, because gelcoat does not surface cure exposed to air.
Follow all the normal paint prep steps. Wash good, use wax and grease remover, sand , W&G again, ETC.
That was an abbreviated list. Follow all the instructions on the clear coat's data sheet.
Old 02-08-2012, 11:21 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
This would be my approach to do a HOK job on a boat. First clean and sand the area to be painted. Then prime with SPI epoxy (probably gray) then with HOK you apply a base coat low in your prefered color then the cosmic glow material would be mixed into SPI intercoat clear and applied then the normal universal clear over that..Hok requires a base to be applied prior to applying the candy material..
Sam
Old 02-08-2012, 11:33 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
I'd think you'd want a marine grade paint..
Question about touching up Base Coat/Clear Coat TR4AGuy Body - Exterior 0 10-08-2011 03:57 PM
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 11:56 AM
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 09:37 AM
Acrylic Enamel vs. Base Coat Clear Coat 70chevy Body - Exterior 175 11-11-2009 03:07 PM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 05:59 AM
