clear coated mags - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 08:47 AM
clear coated mags
any info on how to retsore my mags to the shiny new look, thanx
Old 08-11-2012, 10:51 AM
RWENUTS's Avatar
Welcome coach!!
Check these guys out for wheel polishing stuff!
Eastwood - Auto Body Repair Tools | MIG Welder | TIG Welder | Plasma Cutter | Auto Body Supplies & Accessories
Old 09-07-2012, 01:24 PM
A little late; try these guys too
Buffing & Polishing Supplies - Caswell Inc
If you need to remove old clearcoat, use the finest 'grit' drywall sanding screen DRY. Comes right off, doesnt clog the screen either and if you keep all your strokes in the same direction, it becomes very easy to work it up to the 1000grit (after the clearcoat was removed). Then wipe clean with a good quality thinner/mineral spirits and a white cloth, then polish. Seal with a good polymer wax or use 'Sharkhyde'.
Old 09-07-2012, 02:15 PM
Last journal entry: Paint
Once you get the clear coat off. Sand the wheels smooth with somethiing like 600 sand paper. A buffing wheel on a bench grinder will work to polish them. You don't need any fancy mail order supplies. You need the right compounds which should be avalable close by. The white compound that comes with some of the HF kits works good on aluminum..
Clear Coated Alum. wheel racer57 Hotrodding Basics 7 05-14-2010 08:39 PM
do your mags look like crap? dawg Hotrodders' Lounge 3 04-27-2007 11:55 AM
Two New Online Mags malc Hotrodders' Lounge 0 08-19-2006 03:55 PM
Hotrod mags 78 monte Hotrodders' Lounge 34 07-11-2003 01:09 PM
clear coated aluminum Big Mac Engine 12 12-02-2002 08:24 AM
