I would think 20 minutes would be minimum. What product are you using? Most catalyzed clears can be recoated up to a few hours after initial application. Do you have a "P" sheet on the product you are using?
Vince |
Here is one place I know that sells Rayflex, its there small faq page. But it does have a phone number at the very bottom that might be able to help.
http://www.paintforcars.com/frequent_questions.html |
That is the safest way , like you say with misting the first coat and waiting the 20 minutes then 2 or 3 more wet coats every 20 minutes ...
The reason to fog on at first is to see if your gonna have trouble or not. The challenge is if you do have a problem , you must resist the temptation to try and fix it wet... If there is a problem in the mist coat stop and let it cure up instead of thinking it will somehow be ok if it gets more clear... Just mix up a couple ounces first .. heres one to inspire ya,, http://www.a2zautoforums.com/showthr...2&page=1&pp=20 you'll get it |
Thanks Guy's for all your help, It came out OK for my 2nd paint job, I do have orange peel, I don't think I had the gun adj. correct, Should I wait 1 or 2 weeks and wet sand with some 1200 and spray more clear onto it? thanks again Dennis
| Clear Coating over orangepeel | flipp121 | Body - Exterior | 14 | 01-08-2006 02:12 AM |
| Clear coating bare metal? | Funuk | Introduce Yourself | 2 | 11-23-2004 05:18 PM |
| Clear Coating Aluminum Wheels | nova69 | Body - Exterior | 4 | 06-27-2004 08:51 PM |
| Clear powder coating engine parts | Jag Daddy | Engine | 9 | 11-03-2003 01:38 PM |
| Help with clear coating | anthonycn | Body - Exterior | 8 | 02-01-2003 07:12 PM |
