Clear Coating Single Stage Paint??
Im using 2nd dimension single stage paint, and wanted to know is it worth clearing over? Some people say it gives you a better shine and protection, and some say its not worth it, just go with base coat/clear coat? Just need more opinions. Also how long do you have to wait for the paint to dry before you clear it? Some people say you don't have to even sand it before you apply the clear, just tack rag it before you apply it and shoot it, then some people say you have to wet sand it. Just trying to get some more opinions. This is the way I was going to do it. Wax & Grease Remover, tack rag, 1 coat of 2nd dimension etching primer, says you can sand that after about 30 mins of drying, sand that with 320 grit paper, wax & Grease Remover, tack rag, about 4 to 5 coats of single stage hugger orange 2nd dimension with the fish eye solution, to help prevent them, and says it helps gloss, then i was going to wait to the next day about 8 to 12 hours, tack rag it, a put about 2 to 3 coats of clear on it 2nd dimension. Thats how i was going to do it. Also do you put the fish eye solution in the clear? Let me know what your opinions are, I plan on painting it in 2 to 3 weeks. Thanks Mark.
