Clear film. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2006, 12:58 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Clear film.
Does anyone on here know what the clear film is that the graphics
people use that sticks to the paint but peels off easily.
I've seen it used on car shows and they have it on a roll.
I don't think it's the "Friskit" stuff that the air brushers use,
it looks much larger.
It's a little transparent and easy to draw on, looks like it peels
off mush easier than normal shelf paper and leaves no residue.
Old 08-03-2006, 02:11 PM
STUPID is as STUPID does...
A quick search on Google under "masking film" brought a bunch of hits...
This is one of them...
http://www3.3m.com/catalog/us/en001/...er/output_html
Mark
Old 08-04-2006, 05:19 AM
jcclark's Avatar
The Penny Pincher
Thanks Mark, that's what I was looking for.
I should of thought of that!!!
Old 08-04-2006, 10:31 AM
jcclark's Avatar
The Penny Pincher
After reviewing the 3M film I don't think that's got a sticky back.
Their film is said to "cling" to the body but nowhere mentions adhesive
or for art work. I think their film is just for masking, just like paper.
I am looking for something to peel and stick.
Old 08-04-2006, 11:26 AM
What are you using it for? This stuff will work with an airbrush just fine if that is your purpose. The low psi won't lift it.
Mark
Old 08-07-2006, 03:56 AM
mylar
You can also use mylar and a 3M spray adhesive. There's an electric 'burner' you can use to cut (melt) it into the desired pattern while it's on the car. The pieces can be lifted off, then set back into place without adding more adhesive. The burner looks like one of the old woodburners that came in a kit, only it's low heat and won't damage the paint.
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 05:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 08:08 PM
Painting and Clear with PPG, what do I do next?????? harrija5 Body - Exterior 16 02-03-2005 08:50 PM
