clear got keyed - what grit to use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 04:52 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
Well the car got keyed. It's only in the clear though. It didn't go through to the base.
I haven't worked in the industry for some time. I forget which grit to use.
I've got some 600 wet onhand. Is that too coarse so as to polish afterwards or should I go with higher grit before polishing?
Old 08-10-2008, 05:13 PM
I would not use 600 grit start with 1000 or 1500 and work up from their,
Old 08-11-2008, 01:35 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
I'd suggest a bucketful of some #2 limestone gravel. Start at the key-wielder's feet and work your way up; save the head for last. Might want to switch to finer #10's for that. Oh, wait, you meant "polish" as in doing the clearcoat. Nevermind.
Still think a little old-fashioned stoning would fit the crime -- stopping a bit short of the "to death" part. Ok, maybe just make him polish it out with fingertips and rubbing compound.
Old 08-14-2008, 11:55 PM
Wiki Edits: 29
Thanks rising. Gonna be more labour intensive than I thought. Oh well...
At least it's not the Impala (although it's due for a paint job), it's the daily driver. I could be a lot more upset. But still I don't understand why someone would do that even if wife or I may have inadvertently ticked someone off on the road with a bad maneuver. I think most of us have dreams of catching these pieces of * in the act. I like your version, Grouch.
Old 08-15-2008, 06:55 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Depends on if it's OEM clear or you sprayed it and it's got some build.
OEM and it's a good gray pad scuffing,waterbourn cleaner and reclear or 1000 wet and same deal if you layed it.
Clear coat will fill and hide a LOT of issues and as long as the scratch is CLEAN and the rest is scuffed,your good to go.
HANG them HIGH!!!!!!. By their ball's preferably.
Old 08-31-2008, 01:03 PM
In Texas
"He deserved killin"
is a viable defense?
Wetsanding/final buffing q's mpaq Body - Exterior 38 09-03-2009 01:15 PM
what grit sandpaper for clear blow-in?? hemi43 Body - Exterior 5 06-04-2007 01:12 PM
Can you respray clear over dried clear.. makaveli200369 Body - Exterior 9 08-21-2006 08:46 PM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 06:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
