hi i kustom paint bikes. when i do a frame i use a smaller HVLP gun. and put on lite coats. ive been doing these for 6 yrs and have had no problems.and when i do the clear I Mix 4-parts clear 1 part reducer 1 part hardener. also pic up some 4000 grit sanding pads for hand sanding
do you polish the frame afterwards? i have enough clear on there now i'm sure i can get it to look good if i polish it but i've never really tried sanding and polishing round tubing before? thanks |
frame work
if it looks realy smooth thats what i use the 4000 grit for. if u have a few small runs they should be no problem a run is just a high spot. take 800 grit and carefully (a little at a time) wet sand it till its gone if u see the water off the paper change color stop!!! so u dont sand to deep. after that you should be able to wet sand with 1500 2000 4000 i hand buff out the frame use a spare wool bonnet with 3M rubbing compound and final glaze. www.wayneskustompaint.com
if while clearing you get runs just work them to the bottom and let it drip. buffing a frame sucks with any buffer. i just blast them wet and let it flow.
| Problems with clear; fisheyes, never dries | joewhite | Body - Exterior | 4 | 10-01-2006 06:05 AM |
| Can you respray clear over dried clear.. | makaveli200369 | Body - Exterior | 9 | 08-21-2006 07:46 PM |
| Clear, No Clear, or Clear + Base? | tallpaul | Body - Exterior | 16 | 01-21-2006 05:30 PM |
| Critique My Frame | STATUTORY GRAPE | Suspension - Brakes - Steering | 23 | 12-21-2005 08:51 PM |
| base coat clear coat | wally | Body - Exterior | 8 | 12-12-2005 06:44 PM |
