Clear, No Clear, or Clear + Base? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-21-2006, 02:59 PM
boatbob2
sealing the carport prior to painting
you are correct,i should have said use NEW tarps to seal the carport prior to painting.,much stronger than clear plastic,but plastic is ok too.
  #17 (permalink)
Old 01-21-2006, 05:30 PM
Old fart paint(OEM)tech
I was pretty sure you were talking about new ones ....
single stage vs. base clear? CAMARO Body - Exterior 38 01-30-2009 11:03 AM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
Base And Clear PAS55 Body - Exterior 14 09-30-2005 08:45 AM
pinstriping base coat / clear coat apehanger mike Body - Exterior 1 01-30-2005 12:28 PM
Ignition timing advance question. Terje Engine 14 07-31-2004 04:03 PM
