Clear recoat window.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 08:56 AM
I am wanting to put 1-2 more coats of clear on my project...I sprayed the clear about a week ago, let cure for a week, then sanded all spots with 800 grit...I am now ready to spray the final coats but Im a little concerned about missing the recoat window by so long. I was under the impression sanding it would ensure proper adhesion but I want to make sure this is correct...
I am using all Urekem products, the clear is MS 2k Poly clear UC-410
Thanks
Old 04-24-2011, 09:10 AM
If it's sanded the recoat window means nothing, AS LONG AS the clear is fully cured. If it wasn't subjected to 65 degrees for a number of hours at the very least it may not be cured, that is a whole different ball game. Also, if you didn't apply very much and have sanded it thru or thin and your basecoat isn't catalyzed you can be in trouble there as well.
But if the clear film is thick enough from that first application and has fully cured. You can sand and recoat it anytime you want from now to the end of time.
Old 04-24-2011, 09:27 AM
Ok thanks...That is what I thought, sometimes just need a bit of reassurance
recoat windows 66 Restomod Body - Exterior 3 10-02-2008 10:53 AM
Dupont epoxy recoat window... wyomingclimber Body - Exterior 1 09-29-2008 09:53 PM
Epoxy recoat window. BIG DOG Body - Exterior 5 08-30-2007 09:14 PM
Time window after primer,body filler, color ,clear BIG DOG Body - Exterior 3 07-20-2006 09:13 PM
mp 170 recoat oldred Body - Exterior 4 12-08-2004 01:39 PM
