Which Clear for Rookie Painters???? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-29-2005, 02:58 PM
Max Wedgie
Thanks cboy! you hit it right on the head. If there is some slight orange peel in the base coat - is it OK to go ahead and clear coat (assuming that you would then wet sand and buff your clear coat)???
Will you be able to see any base coat orange peel under a perfectly flat and polished clear coat?
  #17 (permalink)
Old 03-29-2005, 09:19 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Depends on the definition of "slight"
It's actually hard to peel base unless something is very wrong with the paint mixing,gun set up or conditions. If it looks THAT bad, it WILL show up thru the clear.Not as bad but clear is a good magnifier of any obvious defect.
Now, If the peel is only barely noticable,chances are good that the clear WILL fill the peel and it will look fine. I've goofed a spot or 2 on the base and when shooting the first clear coat was cussing myself until I notice that after flashing off the spots were gone.
Point being,IMO,clear will fill small defects, We DO color sand with 320-600 between coats and those big scratchs are filled.
It's is OK to color sand a solid base and clear IF enough coats of base are layed to prevent cutting thru, the clear is what gives base it's "luster" anyway as most base's are "flat" anyway. It's ALWAY'S best to reshoot another coat of base after color sanding. Metallics are another story all togather.You sand,you reshoot.
  #18 (permalink)
Old 03-30-2005, 08:34 AM
Max Wedgie
Awesome - Thanks for the help guys!
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
The clear test. BarryK Body - Exterior 55 03-25-2005 09:40 AM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 08:08 PM
Painting and Clear with PPG, what do I do next?????? harrija5 Body - Exterior 16 02-03-2005 08:50 PM
Clear, wetsanding, and buffing Questions on my Project ChrisMiddleron Body - Exterior 11 05-25-2004 05:15 AM
