Which Clear for Rookie Painters???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 03:58 PM
Max Wedgie
I have seen numerous posts on clears and such but i need oto know which clear will be best for my situation. I will be applying PPG Global base in my home booth at around 65-70 degrees. I am looking for something that will ley out really well and (if needed) wet sand and buff to perfection.
I will be using a Sata RP with a 1.3 tip.
Old 03-22-2005, 07:05 PM
Wiki Edits: 49
Definitely stay with the PPG Global line. There are at least 6 different clears in that line that will work for you. Personally I would recommend D894 Global High Solids Clear. It will dry in the temps you're spraying in and with the tip you're using you shouldn't have any problems.
Centerline
Old 03-22-2005, 09:12 PM
D893 will also work OK and flow well in those temperatures. D894 will dry much slower and be workable for sanding and buffing for a much longer period of time though. You're using premium products IMO. Allow plenty of time between coats.
Old 03-23-2005, 08:33 AM
Wiki Edits: 49
Yep, that'll work too. The main reason I suggested 894 is because it's high solids and rookies tend to color sand too much and might cut through the clear. Been there, done that.
Centerline
Old 03-23-2005, 11:01 AM
Max Wedgie
How much time ( as specific as you can) between the clear coats?
Old 03-23-2005, 02:15 PM
milo's Avatar
point on positive
seventeen minutes
Old 03-23-2005, 06:50 PM
Wiki Edits: 49
here
Check the product sheet for the clear you're using. PPG "P" sheets can be found here under the product information heading. The "P" sheet is your Bible for any particular paint. It tells you how to mix it, how to spray it, and everything else you need to know about that particular material.
Centerline
Old 03-23-2005, 08:17 PM
Rule of thumb on recoat is if it strings when you touch it, it's too wet. If it's sticky but doesn't string it's ready for an addtional coat. Temps and clear play a big role in the recoat time.
Of course you don't touch it on the panel you touch it on the masked area.
Old 03-23-2005, 08:30 PM
Exactly, the clear shouldn't string up when you lift your finger. Dry times between coats will vary with temperature, humidity, and air movement through your spray booth. 894 does stay open longer than 893 so it usually requires a little more time between coats.
Old 03-24-2005, 08:55 AM
Max Wedgie
Thanks guys! Heres another "rookie" question..... Is it necessary to wet sand the base prior to clearing? (IE: the base lays out good but has slight orange peel). Or will it turn out just as good to leave the "slight" orange peel on the base - shoot 2-3 coats of clear - and then wet sand and buff the clear when it is ready. I guess another way to put the question is: If the clear gets sanded flat and buffed - can you see any orange peel in the base coat?
Old 03-24-2005, 11:01 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I don't know about your base but the DuPont Basecoat I use says
NEVER to sand it.
I have scuffed it with a fine pad for dirt problems but always
have dusted a couple more base coats on after that.
I also would like to know more about this, because I've read
about people sanding the base coat, is this permissable with
different brands? or can you get away with it as long as you put
more base over it?
Old 03-24-2005, 03:44 PM
Wiki Edits: 49
Originally Posted by jcclark
I don't know about your base but the DuPont Basecoat I use says NEVER to sand it.....
Exactly. Some people like to wet sand the base but I don't personally know of a manufacturer that recommends it. For a rookie, the smart answer is absolutely NOT!
Centerline
Old 03-28-2005, 09:12 PM
p8nter's Avatar
I was always told the only time you should sand base is to remove problems or if
sits longer than the recommended recoat window, usualy 24 hours.
Old 03-28-2005, 10:54 PM
You don't want to sand base.
Old 03-29-2005, 06:22 AM
cboy's Avatar
Last journal entry: Finished
If you shouldn't sand base, then Early B's question becomes very important. Assuming a rookie does get some orange peel in the base, will the clear eliminate it? Or do you have to keep sanding out the peel and re-shooting base until it comes out perfect?
Always learning...and sharing what I've learned.
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
The clear test. BarryK Body - Exterior 55 03-25-2005 09:40 AM
New Paint, Clear Scratches real easy?? syclone477 Body - Exterior 11 03-20-2005 08:08 PM
Painting and Clear with PPG, what do I do next?????? harrija5 Body - Exterior 16 02-03-2005 08:50 PM
Clear, wetsanding, and buffing Questions on my Project ChrisMiddleron Body - Exterior 11 05-25-2004 05:15 AM
