-   -   clear still fingerprinting (http://www.hotrodders.com/forum/clear-still-fingerprinting-222245.html)
Rosewood 07-28-2012 04:27 PM
It's been at least a month since I sprayed my car bc/cc using kirker product and it will not cure hard. It fingerprints when it's hot but not after it cools. You can sand and buff to a high gloss but it's not getting any harder. Lacquer thinner or reducer doesn't affect it but this can't be cured. I did reduce the basecoat and clear and I went by the tech sheet flash times. I emailed Kirker a few times and they thought the clear may have skimmed over and trapped solvents. I would have thought with all the heat the solvents would have escaped by now. I thought about the activator but all the parts were sprayed at the same time and two of the pieces(plastic) are cured and do not fingerprint. Any ideas before I get the sandpaper out?
MARTINSR 07-28-2012 06:11 PM
All the flash times in the world mean nothing if it's applied too heavy and or not atomized properly. I have seen where the clear was soft and I mean SOFT after a week because of too much film build.
skip99 07-28-2012 09:31 PM
by heat, you mean jjust temp, or did you put it in the sun, a couple days in direct sun will do the trick, unless there was a hardner issue..
MARTINSR 07-28-2012 10:04 PM
Skip, if it was applied too heavy the solvents are trapped with the top layered over and can't escape. If this is the case you need to sand it and open up the surface and then let it out in the sun.
Rosewood 07-28-2012 11:16 PM
The main part of the car cannot be moved in the sun but the hood, trunk lid and doors have been. I sanded to open it up but it didn't seem to help. There are only two pieces that cured which are plastic but were sprayed at the same time as the rest of the car with the same mix on every coat. I don't think it's the base coat because I sprayed it on too dry, metallics not laying down as they should. That leaves the clear which I sprayed 3 coats, which was also reduced. The activator and reducer were correct for the temperature in the shop. If it wasn't for the 2 plastic pieces that cured I would think it's the activator or just the cheap clear but they dried just fine and are not affected by heat. I even wiped some spots with lacquer thinner and reducer to see if it would dissolve the clear but it doesn't affect it. It's just soft when hot and fingerprints. Even when not hot you can push a fingernail into the clear. Are some clears that soft?
skip99 07-30-2012 11:38 AM
you trying to volunteer me? lol!! let him sand his own car...
Rosewood 07-30-2012 12:11 PM
Everybody meet me at my house Saturday, wear your dirty shirt. :evil:
