Clearance concerns - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2005, 03:56 PM
Clearance concerns
I recently purchased a new 5.0 shortblock, from Ford Racing, to replace my worn-out '89 Mustang engine. I also purchased AFR 165 heads (pedestal style), an E303 (Ford Racing) cam and a set of Ford Racing M-6564-A50 1.7 ratio roller rockers.
I am not terribly experienced in engine building, so I am calling upon the combined wisdom and experience of the forum to either allay or confirm my fears.
My question is this: With the combination of the AFR 165 heads, the E303 cam and the 1.7 ratio rockers, should I be concerned about valve to piston clearance?
Old 05-01-2005, 04:05 PM
I'd be concerned enough to mock it up and check it regardless of what engine or combination. You should check the quench while ur in there also.
Old 05-01-2005, 04:25 PM
lluciano77's Avatar
Do the 165s have 194 valves? If so you should have room.
I have a set of Trick Flow heads with 2.02 valves. I ran the Trick Flow cam with .542"/.563" lift and 224o/232o duration. I had to retard the cam for it to clear. Even then it had .80" clearance.
It is a good idea to check anyway. You never know if the cam might be different than advertised. It is cheap insurance against piston to valve contact.
Clearance Problem Ratoflic Engine 2 12-07-2004 01:26 PM
Pontiac head valve clearance adryan16 Engine 4 03-27-2004 06:49 AM
excessive bearing clearance KeithB123 Engine 5 09-18-2003 10:12 PM
Tire Clearance 68NovaSS Suspension - Brakes - Steering 0 09-15-2003 02:33 PM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 04:34 PM
