Clearance: driveshaft versus H-pipe - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2008, 06:28 PM
For the guys who have a H-pipe crossover on their dual exhaust - what is a good minimum clearance between the H-pipe and the driveshaft? Thanks.
Old 05-02-2008, 06:32 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If the pipe is close to the front u-joint and misses, it probably won't be an issue. The further back the pipe is, the more static clearance you'll need due to the up/down movement of the shaft. It all depends on how much bump/rebound you have in the rear suspension.
Old 05-02-2008, 06:35 PM
Stock leaf springs - but the rear shocks are Lakewood 50/50's - on my 1969 Mercury Montego MX.
Old 05-02-2008, 07:45 PM
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: more,more,more
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
re;clearance;driveshaft versus H-pipe
I would try to give it 1"to 1&1/2" below max travel.
Old 05-02-2008, 07:47 PM
68NovaSS's Avatar
Wiki Edits: 9
Ditto what tech said, move it as far forward as possible. There is no rule or formula, get a bunch of beer drinkin' buddies to jump up and down on the rear bumper the watch underneath maybe?
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 05-03-2008, 06:29 PM
I just finished driving my car with it's new H-pipe dual exhaust. Because of the pre-existing geometry of my dual exhaust in relation to the AOD trans and it's crossmember I had to put my H-pipe so it's maybe nine inches past the collector - so it's underneath about two inches before the front u-joint of the driveshaft. It turns out that I have almost four inches between the driveshaft and the H-pipe. It worked out alot better than I was envisioning. It is a little quieter at idle, seems to bark the tires a bit more with the 1-2 shift and seems to sound a bit more refined compared to how it sounded before when my dual exhaust had no crossover at all!
Old 05-03-2008, 07:09 PM
sprecher48's Avatar
Oddo nut
Wiki Edits: 10
re;clearence;driveshaft versus H-pipe
good move,I was thinking the crossover was further to the rear. Tom
Old 05-03-2008, 07:23 PM
Jmark's Avatar
If the H pipe is welded in, make sure it is BEHIND the trans tail shaft by alteast an inch. Makes pulling the trans a lot easier when it clears the pipe. (don't ask how I know this! LOL)
Mark
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
trans cooler tomco550 Transmission - Rearend 1 10-06-2006 03:44 PM
Exhaust pipe Clearance? Z-Money Pit Engine 5 02-09-2006 09:07 AM
Driveshaft Clearance Streetrodfan Transmission - Rearend 2 05-04-2004 09:15 AM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
