Clearance for Flange Type Bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2008, 03:37 PM
iceman36's Avatar
I have a modified A arm setup using Flange type bushings with a steel tube.
Question is how far should the steel tube protrude past the outside of the bushings on both sides? see sketch A arm
Iceman
Old 10-13-2008, 10:23 PM
There should be no reason for it to protrude beyond either end of the bushings when they are installed into the arm at all! When you put the A-Arm assembly into its brackets or hangers on the frame, the protrusion might actually cause more interference issues, and might need to be shortened anyway....
Linkage Bushings Nova Doug Transmission - Rearend 1 07-05-2007 07:23 PM
Redoing 74 Nova Bushings - Initial Planning topdogger Suspension - Brakes - Steering 8 11-13-2006 10:28 AM
MOOG bushings suck! Jmark Suspension - Brakes - Steering 6 03-26-2006 07:51 AM
TH 350 Intermediate clutch clearance 1969Chevelle Transmission - Rearend 1 08-26-2003 04:34 PM
Polygraphite bushings? Gearhead forever Suspension - Brakes - Steering 2 03-19-2003 06:28 PM
