If they were not like that before, the tires must be different sizes....not likely
To check this, take the tires/wheels off and swap them to the opposite sides....If the problem is still the same, the axle needs to be moved
Ontario Rodders |
Do your side-for-side tire swap but you can also measure the tires as far as width across the tread as well as across their widest (cross section) which is the bulge. These tire could be conceivably be manufactured at different times and in different molds and possibly even in different facilities or even in different countries tho .75 is hard to justify. Much of that info is contained on the writing on the sidewall. Next - do you have a wheel that isn't seated on the axle correctly. They usually index with the raised center, tho some of the "universal" fits do it on the lugs. Then, do you have a spacer behind one wheel and not the other.
Of course, last - rear end alignment. If you swing the axle .375 in one direction, you might have to check 'squareness", that is wheel base dimensions, side to side as well as check the wheel tracking. Specs usually say .062 out of alignment fronts vs the rear with less always better. Cutting the rear - the last possible solution - if it was OK before, then it should be OK afterwards Let us know what you find. Dave W |
Dave is probably right here, but I had the same issue with my '35, and couldn't check side to side clearance when I put the Chassis together, as the Body wasn't on the Frame, so at the time I just put it together.
I have a 4 bar with a panhard bar, and I had less tire clearance on one side and about 3/4" more than I needed on the other-I simply loosened the mounting bolts, then turned in the Panhard rod end, reinstalled and that centered the rear axle-problem fixed-
it sounds like the susp./axle moved over when they lifted the car |
Ramifications on not aligning it.
Thank you for your feedback everyone. The only thing I did thus far is measure both of my mounted tires and they are the same width. I'm hearing different stories from friends if I don't correct the problem (positive and negative). If I left the tires as is, would mechanical problems or tire wear issues arise later.
Axle moved sounds very logical
Sounds to me like these new tires are much larger than the old ones.....Being larger, is it possible that the fender clearance just wasnt noticed before.
The offset should cause any problems, just look a bit odd.....Adjusting the panhard bar will help some
Ontario Rodders |
if it has always been like this, and you just didnt notice before because the older tires were narrower, its going to be a big job to fix it right
if the tire that is closer to the fender, still doesnt rub, i would leave it alone. you can only see one side of the car at a time you could use the panhard bar to pull it a small amount (maybe enough) the problem is it will create bind on the other susp. pieces if pulled to far. if you have the right - lugnut (mag type), wheel stud (large), and wheel offset (centered, not too shallow of back spacing) - combo, you could consider using a thin wheel spacer on that one side. |
Adjusting the panhard bar can center the tires between the fenders, but you still need to be concerned that the rear tires are aligned with the front tires. Couldn't it be that the fenders are slightly off in shape, and one doesn't have the same clearance as the other?
My clearance is a little different, maybe 3/8 inch, but I have had a 4 wheel alignment check to verify alignment front to back. John |
| How do you have your Alt. mounted | Overdriv | Engine | 1 | 09-03-2009 09:30 AM |
| I got the aluminum rad mounted in my 51 F1 | Mike H | General Rodding Tech | 4 | 04-06-2009 06:12 PM |
| 700R4 spaced out? | rwruther | Hotrodding Basics | 2 | 07-20-2006 07:29 PM |
| how do i get mounted? | Camaro76 | Suspension - Brakes - Steering | 6 | 02-15-2003 05:45 AM |
| Getting Mounted | Camaro76 | Engine | 7 | 01-15-2003 02:54 PM |
