clearcoat/ basecoat - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2002, 08:30 PM
Post clearcoat/ basecoat
A friend painted my car chrysler pearl and then 5 coats of clear with sanding in between coats. Still have pock markes and some orange peel. Can i eventually get this mess cleaned up? Of course it was home garage painted with a good HVLP gun.
Old 09-24-2002, 08:39 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
With alot of sanding and buffing yes, depending on where the orange peel started you may have to reclear it. I'm not familier with the term pock mark, if you can describe it or use another term, I may have more or different advice.
HK
Old 09-26-2002, 06:35 AM
Post
Thanks for the come back King. To me a pock is a indentation in the paint or clear coat about the size of a pencil lead or smaller. hank
Old 09-26-2002, 12:47 PM
Post
Ahhh, I see, well like I said, you may have to reclear, but with alot of messaging and buffing I think you'll be fine. Hope it turns out well for you.
HK
Old 09-26-2012, 06:13 PM
Faith - Respect - Trust
Okay, you have orange peel and "pock marks", sounds like "fish eyes', Fish eyes are a result of contamination either on the car in in the air (both, garage or anywhere the vehicle is being sprayed. This contamination could generally be motor oil, oils from your hands, or other products containing either an oil or silicone base product, (i.e. armoural...walk into any quality Body Shop and ask if this is a recommended product...you will be given a resounding NO). Clean your painting surface as well as your painting area. By the sounds of it I would recommend re-clearing your project, I would not recommend sanding in-between coats. If you are colour sanding and polishing, put on three to four coats, allow ample cure time, (depending on temperature, if room temperature about three weeks, more if cooler). Using a block and wet sand paper, stating with 800 git if orange peel is real bad, and sand until the surface is smooth. graduate to 1200, 1500, 2000 and possibly 2500 grit for easy polish. Hope this helps
Old 09-26-2012, 06:45 PM
Your advice is right on Mr. Widetrack but I think this guy is done with the project the last post was 10 years ago!
I was looking at the poster Halloweenking thinking, I don't remember him and he has 1300 posts, huh? Then I looked at the date, 2002!
Old 09-26-2012, 08:34 PM
ooopppps
New to the site. I'll look at dates from now on. Although I have projects that are almost that old...
Old 09-26-2012, 09:46 PM
"Almost", you're doing better than me! Welcome!
Old 09-26-2012, 11:27 PM
texastomeh's Avatar
Just shows to go you, that there ain't a whole lot that's new under the sun when it comes to screwing up a paint job!!
Also that GOOD advice is timeless!!
BTW: Brian, I'm old and half senile, but I do remember Halloweenking. Seemed to know his stuff about paint and body. Wonder what ever happened to him?
Anybody?
Tom
I wetsanded through my clearcoat!! (and I have lots of tree sap!) fiscus Body - Exterior 4 06-19-2010 12:13 AM
Basecoat Lapmarks Ken's 39er Body - Exterior 8 08-11-2006 06:45 PM
Can I put clearcoat on top of a lacquer paint viperACR Body - Exterior 10 06-18-2004 11:44 AM
Basecoat / Clearcoat question MG_Man Body - Exterior 8 07-13-2003 10:06 AM
Basecoat question? ASAP Custom95Z Body - Exterior 7 03-02-2003 02:54 PM
