Clearcoat on Metallic Lacquer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2002, 05:01 PM
Post Clearcoat on Metallic Lacquer?
I'm going to repaint my car with the original metallic burgundy lacquer paint. Will I have to clear coat it since it is a mettalic paint?
Old 07-29-2002, 06:33 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
You need to talk to your paint supplier about the system you are using. In general the very best paints available today are two part, catalyzed urethane color coat/clear coat SYSTEMS. This stuff is literally like coating your car with hard urethane plastic that will hold it's finish and is color fast indefinitely. Anything else is second best.
If you decide to use lacquer, you most definitely will need to clear coat it. If plan to color sand and polish the finish, you need a coat of clear thick enough so you never touch the color. If you do sand thru to the metalic, the job will be ruined and you will need to repaint.
Old 07-29-2002, 12:30 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
As usuall willy's is correct.
HK
Old 07-29-2002, 05:06 PM
Post
So how many coats of color should I use and how many clear?
Old 07-30-2002, 03:47 AM
Tom Tom is offline
Post
you have to use a laquer clearcoat over laquer,if you use one of the enamel types it will never dry.I had a so-called expert work for me one time who laquered a saab then cleared it with urethane clear, three weeks later it was still like a wet candy apple,couldn't even touch it.I fired the expert for a few other expert jobs,then had to find him to see what he had done to the saab.The clear would dry nicely in the hot sun but by morning it was wet again,I had to do it over myself,now I don't paint saabs anymore
Old 07-30-2002, 05:33 AM
New Member
Post
In the days past before base coat/clear coat systems were available, I use to do a lot of laquer jobs with dau75 clear over them. I never had a problem. You just have to remember to add the right amount of hardner. If you use to little, it will stay soft and if you use to much, it will get gummy.
Old 07-30-2002, 06:18 AM
Wiki Edits: 21
Post
Tom; your experience sounds really strange. i have used the urethane stuff over every conceivable base (lacquer, Testor's model enamel, bare styrene models, urethane, every kind of primer imaginable, house paint, chrome, polished aluminum, etc., etc. Would even paint my dog if he didn't shed and waste the paint!). I am really sloppy about mixing the hardner and have NEVER had any problems like you describe. Must have been the Saab. Buy real American steel next time (preferably pre-'70) and you won't have any trouble!
[ July 30, 2002: Message edited by: willys36@aol.com ]</p>
Lacquer paints ss62 Body - Exterior 7 07-06-2006 03:29 PM
lacquer clear paint sb454chevy Body - Exterior 3 06-09-2006 09:45 PM
Pointers on spraying lacquer? Quadzilla(EFI) Body - Exterior 6 04-14-2006 01:46 AM
Can I put clearcoat on top of a lacquer paint viperACR Body - Exterior 10 06-18-2004 10:44 AM
How long will lacquer primer last? ChrisMiddleron Body - Exterior 2 06-17-2004 05:35 PM
