Anytime you wet-sand a clear and then set in the sun and the scratches disappear, means it was unactivated or the activator is bad, cause by the solvents escaping.
Once the activator gets below 50% of activity, this is when you will see this.
The clear will never be stable, if it has had that much sun life.
The job you are doing, I would only take the clear off, just not worth the risk of re-coating and you end up taking all of it off a year later, when it looks like dried mud.
