Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Clearcoat problem question.
Old 07-05-2012, 07:40 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
Originally Posted by BarryK View Post
Anytime you wet-sand a clear and then set in the sun and the scratches disappear, means it was unactivated or the activator is bad, cause by the solvents escaping.
Once the activator gets below 50% of activity, this is when you will see this.
The clear will never be stable, if it has had that much sun life.
The job you are doing, I would only take the clear off, just not worth the risk of re-coating and you end up taking all of it off a year later, when it looks like dried mud.
Barry, he came out yesterday to see what I was talking about and brought the materials he used...the one thing missing was the activator for the clear. You are DNO with this. Thanks a bunch!
