Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ClearCoat question
  #18 (permalink)
Old 07-07-2012, 02:50 PM
Lizer Lizer is offline
Are you responding to me? I'm talking about final block grit of high build primer (some of it being Slick Sand so I don't want to wet sand) before sealing with epoxy. There won't be any orange peel.
I was not planning on blocking the seal coat epoxy and shooting straight over it with bc 2 hrs later per Barry's instructions. I can get the epoxy to lay down completely smooth with no peel so it shouldn't be an issue. However, if I do end up getting peel (as luck would have it...you know, getting peel when you actually aren't trying to as opposed to the times when I didn't get peel and wasn't necessarily not trying to) then I may have to cut down some of the peel.
I'm painting mine a metallic blue (the 97 Dodge Viper blue).
