Clearcoat Stripper - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2010, 12:30 PM
Clearcoat Stripper
If I use Klean-Strip Aircraft Remover on the clearcoat on my Aluminum wheels will it remove the black stuff in the pictures that I attached? I am having a really hard time sanding that stuff out. How much stripper will I need to strip (4) 16" wheels, a quart or gallon?
Thanks very much guys!
ID:	46585   Click image for larger version
Old 07-05-2010, 02:24 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Looks to me more like pitting than anything..i suppose you could get a quart of stripper and try it as it probably will not hurt anything to give it a try..
Sam
Old 07-06-2010, 12:04 AM
Underground's Avatar
Last journal entry: 54
corrosion pitting is exactly what that is and stripper isnt going to remove it. You need to sand with a more aggressive grit to sand past that and work your way to finer grit before polishing.
Can I Apply Clearcoat on Headlights? Ayh127 Body - Exterior 23 10-31-2011 01:59 AM
I wetsanded through my clearcoat!! (and I have lots of tree sap!) fiscus Body - Exterior 4 06-19-2010 12:13 AM
Spray clearcoat over clearcoat, should I sand first? klingfilm Body - Exterior 4 10-14-2009 06:36 PM
Paint Stripper, can't find? 39chevy Body - Exterior 9 04-04-2009 07:27 AM
