Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clearcoat wetsanding
Old 04-28-2013, 06:27 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
Runs are hard to get straight again. If the car was sanded already, you will need to know how much clear was put on to begin with. The best way to get runs out is to hit them first with a coarse grade sandpaper. 600-800 depending on the severity, then work to finer grit. I would be scared to go back at them again since it was sanded already. You may or may not go through the clearcoat, so be prepared to repaint if you do. You will need a hard flat block to get it straight again, but really, 1500 is too fine (in my opinion) to get that surface flat again.
