Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clearcoat wetsanding
Old 04-28-2013, 06:54 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
You could blend the base over any area that had a burn through (sanded through) the clear coat, however, your better off to clear the entire panel rather than just trying to clear over the area that you re-applied base. Clear is much harder to blend than base coat and clearing the panel should eliminate polishing back a clear blend.
Ray
