Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clearcoat wetsanding
Old 04-30-2013, 08:58 AM
tech69 tech69 is offline
put up or shut up
I personally like a bent razor blade on a fully cured run. You just tilt it at an angle and shave it with a backwards motion to not allow it to dig in but to only shave off what you want. If you do it carefully and the clear is properly cured it will only take a second of 1000 to get any marks out. I outta try a run block but have had great success with a razor. I just can't knock it.
