Clearcoating over Decals - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2011, 04:40 PM
S10 Racer's Avatar
http://www.warsprints.com
Is it possible to clearcoat over vinyl decals? I am thinking of putting some decals on my boat but would like to have a slick finish. Thanks
Old 04-03-2011, 05:36 PM
CQNRQY
Many motorcycles are decaled and have clear coat over them
Old 04-04-2011, 09:28 AM
If you want a smooth finish you need to clear then flat it back to get rid of the step around the decal and then clear again
Old 04-13-2011, 03:40 PM
Clear coating over decals
I do Gold Leaf stripping on Fire Engines and I routinely put two coats of a clear coat over the work. The first to seal it and the second to increase the luster and leaf enhancement. Be sure you use a product for the Clear coat that is compatible with both the decal and the original pint surface it decal has been applied to.
Normbc9
Old 04-14-2011, 08:01 PM
cboy's Avatar
Last journal entry: Finished
This is more of a question than an answer, but personally I would have second thoughts about doing this, particularly if you have not discussed it with the maker of you decal.
The shop that did the vinyl decals for my sedan delivery was quite specific that there was a "life expectancy" for the graphics and that they will fade over time. My solution was to simply assume that every 3-5 years I'd have to remove the decals and replace them. And if I clear coated over it, that would not be possible.
But this raises the question...would the UV inhibitors in the clear coat prevent the fading of the decal to begin with? And that is where your decal supplier should probably be consulted. My guess is, depending on the original quality and inks used, that some would hold up while others might still fade.
So just something to consider.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 04-14-2011, 11:46 PM
put up or shut up
that's a good point. So which would last longer in the sun.... uncleared base coat or a sticker?
Old 04-15-2011, 08:08 AM
302 Z28's Avatar
The sticker, uncleared base coat has little to no UV protection. Uncleard base coat could be compared to uncleared lacquer.
Vince
old decals ...jasper... Hotrodders' Lounge 9 01-02-2012 03:07 PM
Advice needed regarding re clearcoating. disneytoy Body - Exterior 2 02-15-2011 05:59 AM
clearcoating mild steel journeyman Body - Exterior 3 09-30-2009 09:26 PM
OMNI Mtk Solid and Clearcoating jeep Brockway Body - Exterior 2 09-25-2007 04:23 PM
Swampcooler Decals MINING CAMP Hotrodding Basics 0 04-04-2006 07:50 PM
