clearing bmw light..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2004, 05:26 PM
i have a 1993 528 e bmw. the "inspection" light has been on for a long time. how can i clear it?
Old 10-25-2004, 12:14 AM
jeeptuff's Avatar
**** or get off the pot
Pull the bulb out.... Now I think on them Beamers you need the scan tool to reset inspection light. I don't think the pulling the neg battery terminal for 2 minutes works for this application. I may be wrong..
Old 10-25-2004, 01:33 AM
Last journal entry: The floor going in
you can get the service tool to clear the light they are only cheap
they are about 20 over here so they a probely cheaper were you are have a look on ebay.co.uk
Old 03-18-2005, 10:06 AM
Have Gun, Will Paint
I have a same year 325i
the brake inspection light came on.........I changed the breaks but the light stayed on.......I was thinking it must be a bad sencer
Would the service tool work on break light as well, or is it most likely that I have a bad sencer?
Old 03-18-2005, 10:56 AM
That will be a bad sensor remove the wheels and unplug the sensors and see if the light gose out,then plug the sensors back in one by one until the light comes back on then you have found the problem.If that dosent work get someone to watch the light on the dash and you can move the wiring on the sensor,s and the plug for the sensor and see if that brings the light on and off
see ya stuart
Old 03-22-2005, 08:40 PM
Thanks Stuart
Ill do that.
but now I may have a bigger prob.........the SRS light started blinking on me about 3 weeks ago, then it would go off about 5 min. later, but now it would blink and stay on
Now I may have no choice but to take it in to get checked........last thing I want is to be driving down the road, and the bags to go off for no reason
