Cleat Coat Help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-07-2009, 06:40 PM
Vettcross's Avatar
Thanks- Every little bit of info helps. Conversely tho I have seen some that apply CC at a lower PSI
  #17 (permalink)
Old 12-07-2009, 07:07 PM
Vettcross's Avatar
Saw the vid- What PSI do you usually use?
  #18 (permalink)
Old 12-07-2009, 07:13 PM
milo's Avatar
point on positive
23lbs with the trigger pulled,
10 inches from the panel..
start off the panel/helmet
count 1 second per 12 inches of pass.
That art work looks nice by the way
  #19 (permalink)
Old 12-07-2009, 07:25 PM
Vettcross's Avatar
Thanks- That helps me dial it in quite a bit. The last I just show was at 37 psi. I actually got decent results with that. Taking it down a bit should get me even closer to where I need to be.
  #20 (permalink)
Old 12-07-2009, 07:28 PM
milo's Avatar
point on positive
stay in there, don't be afraid to slow your pass down,
http://www.a2zautoforums.com/showthread.php?t=2792
  #21 (permalink)
Old 12-07-2009, 07:46 PM
Vettcross's Avatar
The clear on the helmet is awesome. I'll let you know when I get to that point. Thanks for the tips
  #22 (permalink)
Old 12-07-2009, 08:00 PM
mitmaks's Avatar
Last journal entry: Grille
ya, some clears Ive used do not say anything about reducer. You always want to add reducer to clear in my experience. I'm not sure why they don't tell you that, maybe cause they want you to use more material???
  #23 (permalink)
Old 12-07-2009, 08:06 PM
Vettcross's Avatar
Maybe-I am glad to at least be on the right path with the CC tho. I was starting to get discouraged. I really appreciate the help.
C
  #24 (permalink)
Old 12-07-2009, 08:08 PM
milo's Avatar
point on positive
In some areas it will put the VOC regulation over the limit so
it not advised "legally"..
  #25 (permalink)
Old 12-07-2009, 08:59 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Reducer in excess of what the material manufacturer recommends may result in adverse effects such as dieback and solvent popping, at the least there will usually be some loss of gloss. I think it would serve a painter best to learn the gun setup and technique required to spray the material as it was intended to be sprayed, then learn to tweak the mix to achieve a desired result once a baseline has been established.
Manufacturers minimize the solvents in their products for a reason, because they are necessary evils that really do nothing for the product but reduce viscosity for ease of spraying. Ideally, the urethane resin would have a low enough viscosity to be sprayed with no solvent addition at all.
  #26 (permalink)
Old 12-07-2009, 09:37 PM
001mustang's Avatar
Will you post a photo???
  #27 (permalink)
Old 12-07-2009, 09:38 PM
mitmaks's Avatar
ya, but what about "high solids" clears. There's no way of spraying them without reducer
  #28 (permalink)
Old 12-07-2009, 09:49 PM
Vettcross's Avatar
All I can say is mixing in reducer was the only time I achieved any success spraying this clear. I tried an assortment of PSI (high and low). Different distances to my substrate and other combinations... Without reducer the CC didn't atomize well at all and landed about the size of small pebbles,
  #29 (permalink)
Old 12-07-2009, 10:28 PM
crashtech's Avatar
Technician
Wiki Edits: 17
Just out of curiosity, what is the size of the fluid nozzle on your gun?
  #30 (permalink)
Old 12-08-2009, 04:05 AM
Vettcross's Avatar
The gun that I purchased specifically for CC app is what the specs called for 1.3
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Why do I struggle with bodywork so much Arrowhead Body - Exterior 32 08-16-2007 09:12 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
body line cole5_0 Body - Exterior 13 10-14-2005 03:57 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
