Cleat Coat Help - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-08-2009, 08:54 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Originally Posted by Vettcross
The gun that I purchased specifically for CC app is what the specs called for 1.3
That ought to work fine. Interestingly, looking at the P-sheet for KC-210 reveals that it is a 4:1 clear with 2.1lbs/gal VOC. So it gets mixed 4 parts clear to 1 part hardener. I hope that you have not been mixing in twice as much hardener as recommended, that could be the cause of your sprayability problem, and could cause other problems as well.
It is common for painters to surreptitiously add a bit of reducer to some 2.1 clears that have a higher than average spray viscosity.
http://www.tcpglobal.com/kustomshop/...0606KC210P.pdf
  #32 (permalink)
Old 12-08-2009, 09:09 AM
Vettcross's Avatar
Thanks a lot for your info. I appreciate it
  #33 (permalink)
Old 12-08-2009, 10:26 AM
302 Z28's Avatar
Is the use of a DA sander recomended for use on something very round like a helmet or should I do that by hand?[IMG]
I am not advocating the use of a DA sander to sand that helmet. The use of a DA with the Mirka Abralon pad wet will not harm the helmet in any way. It is next to impossible to remove any appreciable material with the 4000 grit Mirka pads.
Vince
  #34 (permalink)
Old 12-11-2009, 10:22 AM
Something that I feel should be said, if you are going to add reducer to clear the flash time between coats needs to be increased. This will help you avoid solvent popping. Have fun
  #35 (permalink)
Old 12-11-2009, 10:50 AM
cyclopsblown34's Avatar
Colorsanding painter
I have never reduced clear and do have a little color sanding I have to do but not a lot. I think I've missed something. What do you thin Barry's universal clear with?
  #36 (permalink)
Old 12-11-2009, 10:54 AM
Since I stepped up to a SataJet RP, my clear lays out much smoother than with the NR95. I also went to Barry at Souther Polyurethane for my clear, way better results than I ever got with Chromaclear or Nason. Gorgle search Southern Polyurethane, they are a manufacturer of high quality materials at low quality prices and they sell to the public.
  #37 (permalink)
Old 12-11-2009, 12:43 PM
302 Z28's Avatar
Must have never used PPG DCU2002. It is mixed at 4-1-1 ratio.
Vince
  #38 (permalink)
Old 12-11-2009, 01:31 PM
Vince
No sir, never have. I might have to try it at some point. Our PPG rep closed their doors so the closest is an hour away.
Thanks,
Chip.
  #39 (permalink)
Old 12-11-2009, 02:11 PM
302 Z28's Avatar
Thanks,
Chip.
You should, it's great stuff. I was told by Barry that it is pretty much the same formula as SPI's clear, I have never used it either hope to some day though.
Vince
  #40 (permalink)
Old 12-20-2009, 09:22 PM
I believe Barry at SPI says to reduce a High Solids CC defeats the purpose of using HSCC - thins the solids or something like that.
  #41 (permalink)
Old 12-21-2009, 12:03 PM
Last journal entry: Several Car Projects
Finishing is my thing
Figure that I would throw my 2 cents in.
Clear Coat works very well when you have it tuned in and you know exactly how it will spray, lay and dry. But when you don't there are several ways to fix common problems; Runs, sangs, orange peel, overspray, dust nibs, and even scratches.
*Try to keep things as fine (abrasive grain) as possible, this will help tremendously when buffing.
*Random Orbitals (or DA's) are used for finishing and also material removal. One can buy 36 grit to 4,000 grit sand paper. When DA sanding a round part like a helmet, use an interface pad over your regular backup pad. This give you added cushion and conformability. Also turn down you random orbital sander's throttle.
*If I want my paint to lay a little better I sometimes add a little acetone to my paint mix. Carefull not to make the paint/clear coat too runny.
See advice I had posted earlier.
This might help. I have been using 3M systems for a while. The latest one I have run into was just released this summer (2008). It works great!!!
3M Perfect-it Clear Coat Repair System.
There is even a video that goes along with this system.
This system replaces the Dry Clear Coat Repair System (260L - White sandpaper) and the old Wetordry (401Q) they used to have.
This other page is a great wealth of information.
Accessories for Wets Sanding.
3M Random Orbital Sanders.
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Why do I struggle with bodywork so much Arrowhead Body - Exterior 32 08-16-2007 09:12 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
body line cole5_0 Body - Exterior 13 10-14-2005 03:57 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
