Cleavland On A Windsor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 09:48 PM
nicowarrenrogers's Avatar
I would like to put 1 351c heads on my 302. I would like to know what need to be done for this to hapen. Can i use my stock intake or should i use a 4 barrel torker 2 intake that i have? What modifications do i need?
Old 04-21-2005, 11:57 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I could be wrong, but I think it's more than just a head swap. I believe you need specialty pistons as well. Something I read once, I'm not really a Ford guru.
Old 04-22-2005, 12:31 AM
aka Duke of URL
-This article- will give a brief explanation on how to go about it. The procedure is the same for a 289/302 as the 351W. The only difference will be the required intake manifold.
PRICE ENGINEERING makes the intakes and even offers spacers that will allow 5.0L EFI to be put against the Cleveland head.
If you find BOSS 302 heads and intake, it will mount directly to your 302 saving you a lot of modification costs.
Just do a search on CLEVOR ENGINE and most everything you will need to know will be on the net.
parts for 351 windsor Doug Renton Engine 5 09-13-2009 02:18 PM
Ford 351 Windsor Teardown & Rebuild 101 nightrain_rod Engine 10 07-20-2008 01:57 AM
Question about a 351 Windsor jus102004 Engine 5 02-05-2004 02:40 PM
351 windsor flexplate FAIRLANE DUDE Transmission - Rearend 1 01-16-2003 12:55 PM
AOD on a 351 Windsor FAIRLANE DUDE Transmission - Rearend 1 10-28-2002 10:11 PM
