cleveland swap into sn95 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2012, 10:25 AM
Any one out there do a 351 Cleveland engine swap into a sn95 (1994 - 1998)mustang? We have a fresh Cleveland looking for a home.
Old 12-19-2012, 12:40 PM
Anglia_Nut's Avatar
I've never done one but it should fit in the engine bay. Is the Mustang a 5.0 car or a 4.6? If it's a 5.0 car the motor mounts might even line up.
Old 12-19-2012, 12:53 PM
Banned
forget the mustang Build a t bucket or a f100. just my 2 cents!
Old 12-19-2012, 01:10 PM
techinspector1's Avatar
Wiki Edits: 326
Are you stuck on a Mustang? There are lighter cars that might be an easier swap and make a faster ride. Are you a pretty fair welder/fabricator?
Begin the Mustang research by putting (SN95 Mustang 351C swap) into google search, start reading and taking notes.
Old 12-19-2012, 01:51 PM
Wiki Edits: 27
swap time
If you are thinking about that much work why not do the 460 swap.
Old 12-19-2012, 01:59 PM
Wiki Edits: 326
Yeah, with an 8-71 strapped on it.
Old 12-19-2012, 02:13 PM
Possibly this reason:
Old 12-19-2012, 06:26 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
94-95 will be 5.0L, 96-98 will be 4.6L unless it's a base model then they'll be a 3.8L v6 no matter what the year. The easiest way to tell them apart by year externally is that the 94-95 have horizontal 3-bar tail lights, where the 96-98 have more traditional vertical 3-bar tail lights. The 4.6L is without a doubt dimensionally larger than the 351c. It's a big engine, even with just the single cammer heads, so the K-member should sit low enough to accomdate the 351c.
I've never heard of it being done, but more power to you. If you started with a 96+ you're going to end up with a car that can handle a big, heavy engine hanging off the front. You'd still be within shooting distance with a 5.0L model, the 351c isn't that much bigger. I'd avoid the v6 though, it's got a weak rear end and softer springs.
Old 12-21-2012, 06:27 AM
The car is a 97 that came with the 3.8 V6 / t5 / 7.5
In the past I built a 83 Fox body with a 460 / C6, presently I have a 70 Mustang coupe with a Powerdyne supercharged 351 Cleveland 4V CJ / T5.
Love the Clevelands.
I figure that a 97 V8 crossmember will be needed, read somewhere that with the stock motor mounts would make the Cleveland sit to high but there are companies that offer lower motor mounts. Special headers may be required.
We just want something different.
Old Mustang Engine Swap bluesman123 Engine 11 12-19-2012 07:08 PM
Will a 390 fe motor bolt up to a 351 cleveland transmission in a 73 mustang Mr. Wormy Engine 9 06-21-2008 11:23 AM
84 mustang V6 to 5.0 swap "70" Cougar Engine 17 10-14-2006 01:35 PM
Custom Fiberglass Front Bumper for SN95 Mustang OurLady Body - Exterior 0 02-23-2006 01:48 PM
need help with mustang swap CARGUY Suspension - Brakes - Steering 3 05-28-2002 04:58 AM
