Clevite 77 Bearing Guard on cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2008, 12:35 PM
Can I use this to lube my cam up prior to install?
Old 04-18-2008, 01:59 PM
Last wiki edit: Quadrajet
Wiki Edits: 7
Are you putting in a flat tappet or roller lifter cam?
If it is flat tappet, then NO! You need to use CleviteŽ Cam Guard, or a similiar EP (extreme pressure) rated lube. This is due to the pressure that the lifter face is exerting on the cam lobe. This is a low expense item that can save your bacon in the end! (unless you like having to replace your cam and lifters on a regular basis!) Paste the EP lube liberaly on your cam lobes lifter faces and distrib gear. You will also want to make sure to follow cam break-in procedure to the letter. Especially the part about ZDDP content in your oil or break-in additive.
However if you are using a roller lifter, then you can probably use the bearing guard and be just fine!
Old 04-16-2013, 11:36 AM
Clevite 77 Bearing Guard vs Cam Guard
I just confirmed with Mahle that Clevite CL400 Cam Guard is the same as their Bearing Guard. The only difference is container size: CL400 Cam Guard comes in 4 oz bottles, and Bearing Guard comes in 8 oz bottles (2800-B2), 1 gallon jugs (2800-B4), 1.33 oz packages (2800-B5), and 15-gallon drums (2800-B15). Also see http://www.cleviteonengine.com/publi...s/EK-20-05.pdf for their own product listing.
roller cam failure? 68chevelle_ss Engine 8 11-17-2003 04:25 PM
oversize cam bearing for LS-1 ? carcrazy1 Engine 2 09-15-2003 11:56 AM
Cam Bearing Question. DoubleVision Engine 4 04-21-2003 11:21 AM
Cam Bearing 70 nova Engine 3 04-14-2003 06:42 PM
Oddball Cam source? Biggarmike Engine 3 02-02-2003 10:52 AM
